This is a four-flute, 50mm diameter TCT router cutter for cutting tenons or flattening a slab of timber with repeated cuts. It has a 20mm cutting depth. Two of the cutting edges are down-shear blades for the shoulder and the other two up-shear for a clean face to the tenon. This cutter is designed for tenoning where a large area needs to be recessed or for surface flattening. It has a 58mm long shank for improved reach when used in a router table.
Shank diameter 1/2, overall Length: 78mm, maximum speed 18,000rpm.
Note: This is a large cutter for use with jigs like a slab jig or use in a router table.
X = Depth of Cut 20 mm
D = Overall Diameter 50 mm
Web Attribute Set Straight Router Cutters Globale Group: no-se-fi-10
EAN Barcode 5052511124350
