{"product_id":"axcaliber-four-flute-tenon-milling-cutter-long-shank-1-2","title":"Axcaliber Four Flute Tenon\/Milling Cutter Long Shank 1\/2\"","description":"\u003cp\u003eThis is a four-flute, 50mm diameter TCT router cutter for cutting tenons or flattening a slab of timber with repeated cuts. It has a 20mm cutting depth. Two of the cutting edges are down-shear blades for the shoulder and the other two up-shear for a clean face to the tenon. This cutter is designed for tenoning where a large area needs to be recessed or for surface flattening. It has a 58mm long shank for improved reach when used in a router table.\u003c\/p\u003e\u003cp\u003eShank diameter 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e, overall Length: 78mm, maximum speed 18,000rpm.\u003c\/p\u003e\u003cp\u003eNote: This is a large cutter for use with jigs like a slab jig or use in a router table.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"Default Title","offer_id":54118428770651,"sku":"107588","price":95.58,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107588_xl.jpg?v=1789779366","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-four-flute-tenon-milling-cutter-long-shank-1-2","provider":"Axminster Tools","version":"1.0","type":"link"}
