This is a four-flute, 50mm diameter TCT router cutter for cutting tenons or flattening a slab of timber with repeated cuts. It has a 20mm cutting depth. Two of the cutting edges are down-shear blades for the shoulder and the other two up-shear for a clean face to the tenon. This cutter is designed for tenoning where a large area needs to be recessed or for surface flattening. It has a 58mm long shank for improved reach when used in a router table.
Shank diameter 1/2
Note: This is a large cutter for use with jigs like a slab jig or use in a router table.
