{"product_id":"axcaliber-intumescent-strip-cutters","title":"Axcaliber Intumescent Strip Cutters","description":"\u003cp\u003eTo comply with current fire regulations, intumescent strips must be fitted to fire check doors or frames to delay the passage of fire between different areas in a building. Although the grooves for the Intumescent strip can be cut with standard twin flute cutters, these bearing guided cutters will make a cleaner cut and the router has a larger support area by working from the face or back of the door.\u003c\/p\u003e\u003cp\u003eAxcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"10 mm \/ 24 mm (15\/16\")","offer_id":54161249435995,"sku":"951278","price":29.18,"currency_code":"GBP","in_stock":true},{"title":"15 mm \/ 24 mm (15\/16\")","offer_id":54161249468763,"sku":"951280","price":31.58,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/951278_xl.jpg?v=1790094757","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-intumescent-strip-cutters","provider":"Axminster Tools","version":"1.0","type":"link"}
