Axcaliber
Axcaliber Keyhole Cutters
SKU: 666224
£12.88
£10.73 Excl. VAT
  • Designed to create a keyhole recess
  • For attaching frames and fitments, flush to the wall
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps minimise resin build-up
  • 666222 has a width of groove (C) of 3.2mm
  • 666223 & 666224 have a width of groove (C) of 4.8mm
Choose from our useful range of keyhole cutters, designed for creating a keyhole type recess and to attach frames and fitments flush to the wall.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 12.7 mm (1/2")
D = Overall Diameter 12.7 mm (1/2")
C = Width of Groove 4.8 mm (3/16) Web Attribute Set: Drawer Pull & Keyhole & Mitre Lock Router Cutters C: 4.8 D: 12.7 E: 6.35 X: 12.7
EAN Barcode 5052511030644
