{"product_id":"axcaliber-kitchen-worktop-cutter-long-shank","title":"Axcaliber Kitchen Worktop Cutter (Long Shank)","description":"\u003cp\u003eWhen fitting kitchen worktops using a worktop jig, it is necessary for the router cutter to be long enough to extend below the bottom of the worktop but retain a sufficient length of shank in the router collet. This can be difficult to achieve with some routers and when you add an extension to the router such as a sub-base a long shank is needed to provide sufficient protrusion from the base. It's critical that the router bit is inserted to the K Line as moving away from the line causes instability. With this in mind we have introduced a worktop cutter featuring a longer shank than usually found on this type of cutter. This ensures you have enough reach to cut safely through the work piece. These cutters also feature a bottom cut insert for efficient plunge cuts. 50mm depth of cut, 12.7mm diameter and 107mm overall in length.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"1","offer_id":54117480530267,"sku":"502523","price":25.28,"currency_code":"GBP","in_stock":true},{"title":"3","offer_id":54255642116443,"sku":"719483","price":69.78,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/502523_xl.jpg?v=1789766625","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-kitchen-worktop-cutter-long-shank","provider":"Axminster Tools","version":"1.0","type":"link"}
