A great value cutter for a one off job or those times when it may not be a good idea to use your best high quality expensive cutter. This 1/2" TCT router cutter will cut solid wood and laminate kitchen worktops, leaving a clean finish for a close fitting joint, when used with a worktop jig and 1/2" router. Twin flutes ensure smooth and efficient cutting. With a cutting depth of 51mm it is ideal for general worktop
EAN Barcode 5052511125951
