When fitting kitchen worktops using a worktop jig, it is necessary for the router cutter to be long enough to extend below the bottom of the worktop but retain a sufficient length of shank in the router collet. This can be difficult to achieve with some routers and when you add an extension to the router such as a sub-base a long shank is needed to provide sufficient protrusion from the base. It's critical that the router bit is inserted to the
Axcaliber
Axcaliber Kitchen Worktop Cutters (Long Shank) Set of 3
| EAN Barcode | 5052511106004 |
