{"product_id":"axcaliber-m42-premium-bandsaw-blades","title":"Axcaliber M42 Premium Bandsaw Blades","description":"\u003cp\u003ePremium saw blades use M42 high-speed steel with 8% Cobalt which has been welded to a spring steel alloy backing. This results in a material that has a far greater resistance to heat and abrasion, allowing improved cutting performance in those materials that might have proved troublesome with a 'standard' blade. Many types of material can be cut with ease, all metals including hard steels when the blade is fitted to a slow running metal cutting bandsaw, or all timbers including abrasive timbers such as teak as well as man-made boards like mdf and chipboard when using a higher blade speed on a wood cutting bandsaw. M42 blades are so resilient that reclaimed timber presents no difficulties, as the blade will slice easily through the odd nail buried under the surface. N.B. Due to the possibility of stress fracture we do not recommend the use of these blades on wood cutting bandsaws with a wheel diameter of less than 12” (305mm).  Blades are available in 1\/2\" x 6-10tpi \u0026amp; 10-14tpi, 3\/4\" x 4-6tpi \u0026amp; 10-14tpi.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"1,854 mm (73\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161250910555,"sku":"101399","price":37.48,"currency_code":"GBP","in_stock":true},{"title":"1,854 mm (73\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161250943323,"sku":"101427","price":34.68,"currency_code":"GBP","in_stock":true},{"title":"3,657 mm (144\") \/ 25.4 mm (1) \/ 2014-10-01 00:00:00 +0100","offer_id":54161250976091,"sku":"103255","price":57.5,"currency_code":"GBP","in_stock":true},{"title":"3,086 mm (121.1\/2\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251008859,"sku":"103797","price":57.88,"currency_code":"GBP","in_stock":true},{"title":"3,086 mm (121.1\/2\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251041627,"sku":"103798","price":53.38,"currency_code":"GBP","in_stock":true},{"title":"3,086 mm (121.1\/2\") \/ 19 mm (3\/4 ) \/ 2026-06-04 00:00:00 +0100","offer_id":54161251074395,"sku":"103799","price":52.98,"currency_code":"GBP","in_stock":true},{"title":"3,886 mm (153\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251107163,"sku":"103807","price":64.68,"currency_code":"GBP","in_stock":true},{"title":"3,886 mm (153\") \/ 19 mm (3\/4 ) \/ 2026-06-04 00:00:00 +0100","offer_id":54161251139931,"sku":"103808","price":67.68,"currency_code":"GBP","in_stock":true},{"title":"3,352 mm (132\") \/ 19 mm (3\/4 ) \/ 2026-06-04 00:00:00 +0100","offer_id":54161251172699,"sku":"105220","price":57.78,"currency_code":"GBP","in_stock":true},{"title":"3,352 mm (132\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251205467,"sku":"105223","price":60.58,"currency_code":"GBP","in_stock":true},{"title":"2,305 mm (90.3\/4\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251238235,"sku":"105346","price":44.18,"currency_code":"GBP","in_stock":true},{"title":"2,305 mm (90.3\/4\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251271003,"sku":"105347","price":44.18,"currency_code":"GBP","in_stock":true},{"title":"2,606 mm (102.3\/4\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251303771,"sku":"105358","price":48.98,"currency_code":"GBP","in_stock":true},{"title":"2,606 mm (102.3\/4\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251336539,"sku":"105359","price":48.98,"currency_code":"GBP","in_stock":true},{"title":"3,600 mm (141.3\/4\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251369307,"sku":"110827","price":64.58,"currency_code":"GBP","in_stock":true},{"title":"3,600 mm (141.3\/4\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251402075,"sku":"110828","price":64.58,"currency_code":"GBP","in_stock":true},{"title":"2,920 mm (115\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251434843,"sku":"110974","price":54.28,"currency_code":"GBP","in_stock":true},{"title":"2,920 mm (115\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251467611,"sku":"110975","price":54.28,"currency_code":"GBP","in_stock":true},{"title":"2,420 mm (95.1\/4\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251500379,"sku":"111954","price":45.88,"currency_code":"GBP","in_stock":true},{"title":"2,420 mm (95.1\/4\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251533147,"sku":"111955","price":45.98,"currency_code":"GBP","in_stock":true},{"title":"2,552 mm (100.1\/2\") \/ 19 mm (3\/4 ) \/ 2026-06-04 00:00:00 +0100","offer_id":54161251565915,"sku":"211501","price":45.28,"currency_code":"GBP","in_stock":true},{"title":"3,124 mm (123\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251598683,"sku":"211502","price":57.48,"currency_code":"GBP","in_stock":true},{"title":"3,124 mm (123\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251631451,"sku":"211503","price":55.98,"currency_code":"GBP","in_stock":true},{"title":"3,124 mm (123\") \/ 19 mm (3\/4 ) \/ 2026-06-04 00:00:00 +0100","offer_id":54161251664219,"sku":"211504","price":53.78,"currency_code":"GBP","in_stock":true},{"title":"3,405 mm (134\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251696987,"sku":"211505","price":60.68,"currency_code":"GBP","in_stock":true},{"title":"3,405 mm (134\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251729755,"sku":"211506","price":61.48,"currency_code":"GBP","in_stock":true},{"title":"3,405 mm (134\") \/ 19 mm (3\/4 ) \/ 2026-06-04 00:00:00 +0100","offer_id":54161251762523,"sku":"211507","price":58.58,"currency_code":"GBP","in_stock":true},{"title":"3,820 mm (150.1\/2\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251795291,"sku":"211508","price":66.98,"currency_code":"GBP","in_stock":true},{"title":"3,820 mm (150.1\/2\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251828059,"sku":"211509","price":67.88,"currency_code":"GBP","in_stock":true},{"title":"3,480 mm (137\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251860827,"sku":"211511","price":62.68,"currency_code":"GBP","in_stock":true},{"title":"3,480 mm (137\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251893595,"sku":"211512","price":62.88,"currency_code":"GBP","in_stock":true},{"title":"1,470 mm (58\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251926363,"sku":"211514","price":30.98,"currency_code":"GBP","in_stock":true},{"title":"3,050 mm (120\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161251959131,"sku":"211991","price":56.28,"currency_code":"GBP","in_stock":true},{"title":"3,050 mm (120\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161251991899,"sku":"211992","price":54.98,"currency_code":"GBP","in_stock":true},{"title":"2,235 mm (88\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252024667,"sku":"212020","price":42.98,"currency_code":"GBP","in_stock":true},{"title":"2,299 mm (90.1\/2\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252057435,"sku":"212021","price":43.98,"currency_code":"GBP","in_stock":true},{"title":"2,235 mm (88\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252090203,"sku":"212022","price":42.98,"currency_code":"GBP","in_stock":true},{"title":"2,490 mm (98\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252122971,"sku":"212023","price":47.28,"currency_code":"GBP","in_stock":true},{"title":"2,438 mm (96\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252155739,"sku":"212024","price":46.48,"currency_code":"GBP","in_stock":true},{"title":"2,552 mm (100.1\/2\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252188507,"sku":"212025","price":48.28,"currency_code":"GBP","in_stock":true},{"title":"2,845 mm (112\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252221275,"sku":"212026","price":52.98,"currency_code":"GBP","in_stock":true},{"title":"1,790 mm (70.1\/2\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252254043,"sku":"212027","price":35.98,"currency_code":"GBP","in_stock":true},{"title":"1,790 mm (70.1\/2\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252286811,"sku":"212028","price":35.98,"currency_code":"GBP","in_stock":false},{"title":"2,096 mm (82.1\/2\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252319579,"sku":"212029","price":40.88,"currency_code":"GBP","in_stock":true},{"title":"2,096 mm (82.1\/2\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252352347,"sku":"212030","price":40.88,"currency_code":"GBP","in_stock":true},{"title":"2,299 mm (90.1\/2\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252385115,"sku":"212031","price":43.98,"currency_code":"GBP","in_stock":true},{"title":"2,438 mm (96\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252417883,"sku":"212032","price":45.48,"currency_code":"GBP","in_stock":true},{"title":"2,490 mm (98\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252450651,"sku":"212033","price":47.28,"currency_code":"GBP","in_stock":true},{"title":"2,552 mm (100.1\/2\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252483419,"sku":"212034","price":48.28,"currency_code":"GBP","in_stock":true},{"title":"2,845 mm (112\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252516187,"sku":"212035","price":52.98,"currency_code":"GBP","in_stock":true},{"title":"1,440 mm (56.3\/4\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252548955,"sku":"508217","price":30.48,"currency_code":"GBP","in_stock":true},{"title":"1,784 mm (70.1\/4\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252581723,"sku":"508220","price":35.98,"currency_code":"GBP","in_stock":true},{"title":"3,035 mm (119.1\/2\") \/ 27 mm (1.1\/16) \/ 2026-06-04 00:00:00 +0100","offer_id":54161252614491,"sku":"508341","price":61.42,"currency_code":"GBP","in_stock":true},{"title":"2,270 mm (89.1\/2\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252647259,"sku":"950109","price":43.88,"currency_code":"GBP","in_stock":true},{"title":"2,270 mm (89.1\/2\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252680027,"sku":"950110","price":42.68,"currency_code":"GBP","in_stock":true},{"title":"1,640 mm (64.1\/2\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252712795,"sku":"951593","price":33.68,"currency_code":"GBP","in_stock":true},{"title":"3,327 mm (131\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252745563,"sku":"951664","price":60.28,"currency_code":"GBP","in_stock":true},{"title":"3,327 mm (131\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252778331,"sku":"951665","price":60.28,"currency_code":"GBP","in_stock":true},{"title":"3,860 mm (152\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252811099,"sku":"951666","price":68.68,"currency_code":"GBP","in_stock":true},{"title":"3,860 mm (152\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161252843867,"sku":"951667","price":68.68,"currency_code":"GBP","in_stock":true},{"title":"3,860 mm (152\") \/ 19 mm (3\/4 ) \/ 2026-06-04 00:00:00 +0100","offer_id":54161252876635,"sku":"951668","price":65.18,"currency_code":"GBP","in_stock":true},{"title":"4,190 mm (165\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252909403,"sku":"951669","price":72.98,"currency_code":"GBP","in_stock":true},{"title":"4,190 mm (165\") \/ 19 mm (3\/4 ) \/ 2026-06-04 00:00:00 +0100","offer_id":54161252942171,"sku":"951670","price":72.18,"currency_code":"GBP","in_stock":true},{"title":"4,597 mm (181\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161252974939,"sku":"951671","price":80.48,"currency_code":"GBP","in_stock":true},{"title":"4,597 mm (181\") \/ 19 mm (3\/4 ) \/ 2026-06-04 00:00:00 +0100","offer_id":54161253007707,"sku":"951672","price":77.98,"currency_code":"GBP","in_stock":true},{"title":"4,445 mm (175\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161253040475,"sku":"951673","price":76.98,"currency_code":"GBP","in_stock":true},{"title":"2,560 mm (100.3\/4\") \/ 12.7 mm (1\/2) \/ 2026-10-06 00:00:00 +0100","offer_id":54161253073243,"sku":"953417","price":49.98,"currency_code":"GBP","in_stock":true},{"title":"2,560 mm (100.3\/4\") \/ 12.7 mm (1\/2) \/ 2014-10-01 00:00:00 +0100","offer_id":54161253106011,"sku":"953418","price":48.38,"currency_code":"GBP","in_stock":true},{"title":"2,560 mm (100.3\/4\") \/ 19 mm (3\/4 ) \/ 2026-06-04 00:00:00 +0100","offer_id":54161253138779,"sku":"953419","price":45.38,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/953419_xl.jpg?v=1790094906","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-m42-premium-bandsaw-blades","provider":"Axminster Tools","version":"1.0","type":"link"}
