Axcaliber bandsaw blades are manufactured at Axminster using advanced CNC machining, high precision digital measuring equipment and specialised heat treatment facilities. Detailed quality checks are performed at each stage of manufacture using the most modern inspection equipment.
These blades are made for small metal cutting bandsaws, are durable and will produce a straight, smooth cut. The 10tpi blades are made from high carbon stock, whereas the 14tpi blades are made from triple heat treated M42 stock for long life.
Made in Britain Yes
Bandsaw Blade Length 1,440 mm (56.3/4")
Bandsaw Blade Width 12.7 mm (1/2)
Bandsaw Blade Tpi 10
Bandsaw Blade Type High Carbon
Web Attribute Set Metal Cutting Blades
EAN Barcode 5052511071456
