Axcaliber
Axcaliber Milling Cutter with Top Bearing
SKU: 952561
£21.18
£17.65 Excl. VAT
  • Axcaliber milling cutter with top bearing
  • 1/2(12.7mm) diameter with 8mm depth of cut
  • PTFE coating helps minimise resin build-up
This Axcaliber milling cutter with a tight radius and top bearing is the perfect bit for sign making or many kinds of template or recessed work.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 8 mm (5/16")
D = Overall Diameter 12.7 mm (1/2")
Web Attribute Set Rebate Router Cutters D: 12.7 X: 8
EAN Barcode 5052511054046
