Axcaliber
Axcaliber Panel Mould Beading Cutters
SKU: 666028
£13.98
£11.65 Excl. VAT
  • Use with guide bush and template for decorative panel work
  • Produce ovolo or rounding over profiles on edges
  • Twin flute cutters with plunge cut
  • High shear-cut angle for cleaner finish
  • PTFE coating helps minimise resin build-up
Panel mould beading cutters which can be used with a suitable guide bush for decorative panel work or edge mouldings.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 8 mm (5/16")
D = Overall Diameter 9.5 mm (3/8")
R = Radius 3.2 mm (1/8")
Web Attribute Set Ovolo & Rounding Over Router Cutters D: 9.5 R: 3.2 X: 8
EAN Barcode 5052511029105
