{"product_id":"axcaliber-premium-216mm-tct-saw-blades","title":"Axcaliber Premium 216mm TCT Saw Blades","description":"\u003cp\u003eThese blades are particularly suited for use with table and mitre saws. They offer high performance and high quality of surface finish.\u003c\/p\u003e\u003cp\u003eAxcaliber Premium circular saw blades are from the world's largest blade manufacturer. Using the latest production techniques and the best materials, the Premium blades feature micro grain TCT tips and resin dampened laser cut plates, which substantially reduce noise whilst cutting. The \"Premium\" range is the blade of choice for all joinery and cabinet workshops demanding the very best performance.\u003c\/p\u003e\u003cp\u003eThe fine crosscut blades feature Alternate Top Bevel (ATB) ground teeth, ensuring a clean, fast cut. The tops of the teeth are bevelled alternately at approximately 15\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. This tooth configuration bears a sharp pointed tip that provides a neat clipping action for very fine finishes. Two teeth will span the entire width of the kerf. It produces very low cutting pressures that almost eliminate the tendency to tear out. The chips fall free in the chip spaces created by the large side clearance angles.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"General Purpose (24 teeth)","offer_id":54118308118875,"sku":"104934","price":28.1,"currency_code":"GBP","in_stock":true},{"title":"Crosscut (48 teeth)","offer_id":54118308151643,"sku":"104936","price":34.98,"currency_code":"GBP","in_stock":false},{"title":"Crosscut (56 teeth)","offer_id":54118308184411,"sku":"104940","price":37.48,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104934_xl.jpg?v=1789774820","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-premium-216mm-tct-saw-blades","provider":"Axminster Tools","version":"1.0","type":"link"}
