Get the best of both worlds with these two Axcaliber "Premium" circular saw blades. Our Premium blades feature micro grain TCT tips and resin damped laser cut plates.
The 24T rip cut blade has Alternate Top Bevel (ATB) ground teeth, ensuring a clean, fast cut. Large gullets carry the waste away and limiters behind each tooth prevent over feeding.
The 60T fine crosscut blade features trapezoidal ground teeth, known as a Top Centre Ground or Triple Chip (TCG) tooth profile where one flat top tooth is followed by a fractionally higher trapezoidal tooth.This provides an exceptional finish on all woods or manmade boards including faced boards.
The "Premium" range is the blade of choice for all joinery and cabinet workshops demanding the very best performance.
Blade Diameter 254 mm
Maximum RPM 9,000 rpm
Web Attribute Set Circular Saw Blades
EAN Barcode 5052511125685
