Axcaliber
Axcaliber Rebate Cutter Set
SKU: 666162
£30.98
£25.82 Excl. VAT
  • Diameter 35mm
  • Depth of cut 12.7mm
  • Shear cut for best finish
  • SAE4140 steel shank hardened to Rockwell 45 HRC
  • Diamond ground Sandvik micrograin tungsten carbide tip
  • Virtual mirror finish ensures durable, clean cutter
  • PTFE coating helps minimise resin build-up
A very popular rebate set available in 1/4"(6.35mm) or 1/2"(12.7mm) shank sizes, which include four different bearing sizes offering the following depths of rebate: 12.7mm(1/2"),11mm(7/16"), 9.5mm(3/8"), 8mm(5/16"), with a depth of cut up to 12.7mm(1/2"). The carbide tips are set at an angle to give a clean shearing cut.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 12.7 mm (1/2")
D = Overall Diameter 35 mm
Web Attribute Set Rebate Router Cutters D: 35 X: 12.7
EAN Barcode 5052511030149
