{"product_id":"axcaliber-rebate-set-1-2-7-bearings","title":"Axcaliber Rebate Set 1\/2\" (7 Bearings)","description":"\u003cp\u003eA versatile rebate set available in a 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e (12.7mm) shank size, which includes seven different bearing sizes offering the following depths of rebate: 12.7mm, 11.1mm, 9.5mm, 8mm, 6.35mm and 3.2mm and flush cut using the largest bearing. The a depth of cut is up to 19mm. This bottom bearing rebate set allows you to make an endless number of cuts by adjusting the cutting height on the router and changing the bearing on the bit. It can be used to produce rebates; small tenons even in curved work and the carbide tips are set at an angle to give a clean shearing cut.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"Default Title","offer_id":54117954388315,"sku":"506273","price":62.48,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/506273_xl.jpg?v=1789770434","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-rebate-set-1-2-7-bearings","provider":"Axminster Tools","version":"1.0","type":"link"}
