The Axcaliber Ripper Blade 37 is specifically intended for wood processing and deep ripping tasks, fitting only a few larger machines where motors of sufficient capacity are able to handle the 31.75 mm wide blade. The teeth are precision ground using CNC machinery are then induction hardened. Furthermore, to ensure a very long working life, each blade can be re-sharpened up to100% more times than any other similar blade, offering the best possible cutting performance.
Axcaliber
Axcaliber Ripper 37 Bandsaw Blades
- 3,531 mm (139")
- 3,850 mm (151.1/2")
- 3,962 mm (156")
- 4,115 mm (162")
- 4,310 mm (169.1/2")
- 4,425 mm (174")
- 4,430 mm (174.1/2")
- 4,470 mm (176")
- 4,525 mm (178")
- 4,572 mm (180")
- 5,029 mm (198")
- 5,169 mm (203.1/2")
- 4,597 mm (181")
- 4,190 mm (165")
- 5,125 mm (202")
- 3,480 mm (137")
- 3,820 mm (150.1/2")
- 4,010 mm (157")
| Made in Britain | Yes |
| Pack Quantity | 1 |
| Bandsaw Blade Length | 3,531 mm (139") |
| Bandsaw Blade Width | 31.75 mm (1.1/4) |
| Bandsaw Blade Tpi | 1.1 |
| Bandsaw Blade Type | Ripper 37 |
| Web Attribute Set | Ripper 37 Bandsaw Blades |
| EAN Barcode | 5052511103744 |
