A pair of matched cutters used for the fast, accurate and efficient manufacture of sash windows using a router table set-up. The profile cutter will produce the moulding on the stiles and rails and the matching cutter produces the scribe at the ends of the rails and sash bars to fit over it. The profile cutter is 22mm diameter, 10mm radius, with a 18mm depth of cut and the scribing cutter is 25mm diameter, 10mm radius, with a 20mm depth of cut. Available in 1/4(6.35mm) shank only.
Shank Diameter 1/4" (6.35 mm)
R = Radius 10 mm
Web Attribute Set Profile Scribing Router Cutters R: 10
EAN Barcode 5052511039890
