This cutter is used for the fast, accurate and efficient manufacture of sash windows using a router table set-up. It will produce the scribing cut on the ends of the rails and sash bars and profile cutters are available to produce the matching profile on the stiles and rails of the sash. Diameter 25mm Depth of cut 20mm Radius 10mm. Available in 1/4
Axcaliber
Axcaliber Sash Bar Ovolo Scribing Router Cutter
| Shank Diameter | 1/4" (6.35 mm) |
| X = Depth of Cut | 20 mm |
| D = Overall Diameter | 25.4 mm (1") |
| R = Radius | 10 mm |
| Web Attribute Set | Profile Scribing Router Cutters D: 25.4 R: 10 X: 20 |
| EAN Barcode | 5052511048908 |
