Axcaliber
Axcaliber Sash Bar Ovolo Scribing Router Cutter
SKU: 952416
£27.38
£22.82 Excl. VAT
  • Make sash windows quickly and efficiently
  • Matching profile cutter available
  • Reproduces the type of moulding found on many older style window sashes
  • 1/4 shank
This cutter is used for the fast, accurate and efficient manufacture of sash windows using a router table set-up. It will produce the scribing cut on the ends of the rails and sash bars and profile cutters are available to produce the matching profile on the stiles and rails of the sash. Diameter 25mm Depth of cut 20mm Radius 10mm. Available in 1/4(6.35mm)shank only.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 20 mm
D = Overall Diameter 25.4 mm (1")
R = Radius 10 mm
Web Attribute Set Profile Scribing Router Cutters D: 25.4 R: 10 X: 20
EAN Barcode 5052511048908
