These cutter heads have been designed for: rebating from top and from bottom, jointing and grooving in your spindle moulder machines, double-end tenoner and edging machines. Perfect in many materials, but a better result is achieved using chipboard and MDF, wood composites, plastic materials and laminates. Improved design with shear angle. Cutting depth (I)50mm, bore size (F)30mm, 125mm diameter.
Web Attribute Set Spindle Moulding Blocks & Knives
EAN Barcode 5052511106035
