This Axcaliber stile and rail cutter offers an attractive Shaker style profile with the advantage of having just one cutter for the moulding and scribing cuts. You simply alter the height of the cutter in the router table to switch from one operation to the other. The timber should be positioned face down on the table surface for the moulding cuts and face up for the scribing cuts. Excellent for making your own kitchen unit doors. N.B. Recommended timber thickness 18 - 22mm. Please note this cutter is for use in router tables only.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 23 mm
D = Overall Diameter 41 mm (1.5/8")
K = Cutter Angle 15
C = Width of Groove 6.35 mm (1/4) H = Horizontal Depth of Cut: 9.5 mm (3/8") Web Attribute Set: Profile Scribing Router Cutters C: 6.35 D: 41 H: 9.5 X: 23
EAN Barcode 5052511047055
