Looking like an overgrown keyhole cutter, you can use this cutter to cut a T-slot in a workbench or an assembly table. Once cut the T-slot enables you to use Axminster (or Festool) guide rail clamps as hold downs when working on a piece or gluing up. Alternatively a length of hardwood with a T-slot cut along its length can become a custom made or temporary guide rail. in addition, you can cut a T-Slot in nylon if making jigs to your own design. We suggest you remove the bulk of the waste with a straight cutter of the same diameter as the neck of the cutter (dimension E) prior to using the T-slot cutter.
Please note; When using this type of cutter it is recommended to use a small straight cutter first to remove some of the material and help prevent router overload.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 23 mm
D = Overall Diameter 12.7 mm (1/2")
C = Width of Groove 6.5 mm E = Minor Diameter: 8.7 mm Web Attribute Set: Quick Clamps C: 6.5 D: 12.7 E: 8.7 X: 23
EAN Barcode 5052511065011
