{"product_id":"axcaliber-t-slot-cutter-for-track-clamps","title":"Axcaliber T-Slot Cutter for Track Clamps","description":"\u003cp\u003eLooking like an overgrown keyhole cutter, you can use this cutter to cut a T-slot in a workbench or an assembly table. Once cut the T-slot enables you to use Axminster (or Festool) guide rail clamps as hold downs when working on a piece or gluing up. Alternatively a length of hardwood with a T-slot cut along its length can become a custom made or temporary guide rail. in addition, you can cut a T-Slot in nylon if making jigs to your own design. We suggest you remove the bulk of the waste with a straight cutter of the same diameter as the neck of the cutter (dimension E) prior to using the T-slot cutter.\u003c\/p\u003e\u003cp\u003ePlease note; When using this type of cutter it is recommended to use a small straight cutter first to remove some of the material and help prevent router overload.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"Default Title","offer_id":54118119276891,"sku":"101972","price":14.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/101972_xl.jpg?v=1789771681","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-t-slot-cutter-for-track-clamps","provider":"Axminster Tools","version":"1.0","type":"link"}
