{"product_id":"axcaliber-three-wing-slot-cutter-set","title":"Axcaliber Three Wing Slot Cutter Set","description":"\u003cp\u003eDesigned for router table use, this set can be used to create slots, grooves and rebates from 3.2mm to 18mm in depth. The set includes: 4 x three winged cutters 3.2, 4, 4.8, and 6.4mm in width. 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e shank arbor. 21 shims (8 x 0.1mm, 4 x 0.5mm, 5 x 1mm, 2 x 3mm and 2 x 6mm).\u003c\/p\u003e\u003cp\u003eN.B. The carbide edges of the cutters should never touch; arrange the cutters to prevent this. Use only the thicknesses provided in the set. Be sure all cutters are assembled in the correct rotational direction.\u003cspecial id=\"22\"\u003e\u003c\/special\u003eSafety tips:\u003cspecial id=\"23\"\u003e\u003c\/special\u003e Never use the slot cutter set without shims between the cutters. The distance between the cutters can vary from 1mm to 1.5mm. A shim must also be positioned between the ball bearing and the cutters.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"Default Title","offer_id":54117364728155,"sku":"952565","price":75.38,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/952565_xl.jpg?v=1789765985","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-three-wing-slot-cutter-set","provider":"Axminster Tools","version":"1.0","type":"link"}
