Designed for router table use, this matching pair of cutters are excellent for quickly producing a tongue and groove joint in material up to 19mm thick. Each cutter is 47.6mm in diameter with a 22mm bearing which produces a tongue or groove 12.8mm long by 6.35mm wide. (1/2 shank only).
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 19 mm
D = Overall Diameter 47.5 mm (1.7/8")
C = Width of Groove 6.35 mm (1/4) H = Horizontal Depth of Cut: 12.7 mm (1/2") Web Attribute Set: Jointing Router Cutters C: 6.35 D: 47.5 H: 12.7 X: 19
EAN Barcode 5052511054077
