Axcaliber
Axcaliber Victorian Torus Moulding Cutter
SKU: 666181
£39.98
£33.32 Excl. VAT
  • Moulding for plinths and skirting
  • Traditional Victorian style moulding
  • Bottom bearing allows use on curved work
  • High shear-cut angle for cleaner finish
  • PTFE coating helps minimise resin build-up
This cutter will produce a traditional classic moulding of the type used on skirting boards and similar applications. Bottom bearing guidance also allows curved work to be carried out.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 36.5 mm
D = Overall Diameter 31.75 mm (1.1/4")
R = Radius 9.5 mm (3/8")
Web Attribute Set Edge Moulding, Cornice & Handrail Router Cutters D: 31.75 R: 9.5 X: 36.5
EAN Barcode 5052511030293
