This double-ended swivel elbow is a great way to attach a flexible hose to a machine. It offers excellent articulation to a dust hose connection. In effect it is a 15 ball-joint, able to rotate a full 360. It helps prevent your hose from kinking, binding or pulling off the dust extractor. One inlet has an internal bore of 102mm, designed to fit over a 100mm inlet/outlet or another ABS extractor fitting. The second inlet is designed to take a 63mm extraction hose and hose clamp. Both inlets/outlets are 50mm long to ensure a secure connection.
Moulded from durable ABS, the overall length is 230mm, width 165mm.
Overall L x W x H 230 mm x 165 mm
EAN Barcode 5052511128976
