{"product_id":"axminster-15-piece-1-4-6-35mm-router-cutter-set","title":"Axminster 15 Piece 1\/4\" (6.35mm) Router Cutter Set","description":"\u003cp\u003eThe Axminster 15 Piece 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e (6.35mm) Router Cutter Set is the perfect entry level set. It comprises 15 quality router cutters, for use in a 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e router. All 15 can be used in hand held routers and routers fixed in tables. They are tungsten carbide tipped, making them extremely durable. Suitable for use with hardwoods and man-made boards such as MDF and plywood.\u003c\/p\u003e\u003cp\u003eContents:\u003c\/p\u003e\u003cp\u003e1 x bearing guided roman ogee cutter 4mm (5\/32\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) radius x 27mm (1.1\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 25° bearing guided Chamfer cutter x 25.4mm (1\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 3mm (1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) radius bearing guided rounding over cutter x 19mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x bearing guided cove cutter 10mm (25\/64\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) radius x 28.5 (1.\/18\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 15° dovetail cutter x 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 60° V-groove cutter x 16mm (5\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 4mm (5\/32\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) bearing guided slotting cutter x 32mm(1.1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x straight cutter 8mm (5\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) x 20mm (25\/32\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) depth of cut\u003c\/p\u003e\u003cp\u003e1 x 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter flush cutter with bottom bearing x 25.4mm (1\u003cspecial id=\"32\"\u003e\u003c\/special\u003e)\u003c\/p\u003e\u003cp\u003e1 x 45° bearing guided chamfer cutter x 35mm (1.3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x straight cutter 10mm (25\/64\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) x 30mm (1.3\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) depth of cut\u003c\/p\u003e\u003cp\u003e1 x bearing guided rebating cutter x 32mm (1.1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x straight cutter 16mm (5\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) x 30mm (1.3\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) depth of cut\u003c\/p\u003e\u003cp\u003e1 x 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) radius bearing guided rounding over cutter x 25.4mm (1\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 16mm (5\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter flush cutter with top bearing x 25.4mm (1\u003cspecial id=\"32\"\u003e\u003c\/special\u003e)\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118508134747,"sku":"110856","price":24.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/110856_xl.jpg?v=1789783722","url":"https:\/\/www.axminstertools.com\/products\/axminster-15-piece-1-4-6-35mm-router-cutter-set","provider":"Axminster Tools","version":"1.0","type":"link"}
