This quick release bit holder is 150mm in length for a longer reach and holds the bit securely. Suitable for holding 1/4 hex screwdriver bits and other accessories. A spring loaded sleeve locks the bit securely in place. Simply pull back the sleeve to release for a quick change of screwdriver and other bits.
Web Attribute Set Hex Drive Bits
EAN Barcode 5052511142064
