The Axminster LED Worklight is ideal for detailed tasks. Its super bright white light is concentrated like a spotlight, making it excellent for close-up work.
Designed to be used with machinery, it can be securely bolted onto machines. It has a flexible 10 x 420mm swan neck making it fully adjustable to suit your desired location. It has an all metal construction. Due to the low wattage LED bulb, this light generates limited heat.
Web Attribute Set General Machine Accessories
EAN Barcode 5052511138906
