These TCT Planer knives are ideal for machining abrasive exotic timbers or for those regularly preparing hardwoods. Also should be used when machining glued panels. Economically priced and in packs of 3, will fit the Axminster AW106PT2/AH106PT planer thicknessers or similar machines from other brands. Not as sharp as HSS but holds an edge for far longer. 254 x 30 x 3mm. Resharpenable using a Silicon Carbide Green grinding wheel.
Knives TCT
Overall L x W x H 254 mm x 30 mm x 3 mm
Web Attribute Set Planer Knives Number of Knives: 3 To Fit: AW106PT2 600818
EAN Barcode 5052511007707
