This hose is made from galvanised steel spirally wound to give it the flexibility needed when connecting a machine to a dust extractor. In industry this hose is used for ducting smoke and fumes and handling ash etc. It is completely non-flammable, heat and abrasion resistant. In the workshop we recommend its use when grinding or sanding metal and any other application likely to produce sparks, hot or abrasive particles. An appropriate extractor is a must. It has an internal diameter of 32mm (1.1/4
Note: To allow this to fit easily onto the dust outlet of the Ultimate edge, one end has been slightly flared by 1-2mm,
