Axminster 5 in 1 Multi-function Bar Clamps
SKU: 114328
£8.98
  • Five clamping functions in one tool
  • Versatile everyday workholding
  • 120kg (260lb) maximum holding force
  • Use as a bar clamp or spreader
  • Suitable for T-track and MFT workholding
  • Auto-lock mechanism for secure positioning
  • Quick-release lever for fast adjustment
  • High-carbon steel bar and glass fibre reinforced PA6 body
Axminster 5-in-1 Medium Bar Clamp is a versatile multifunction clamp designed to handle a range of everyday clamping and workholding tasks with one adaptable tool. It can be used as a conventional bar clamp or spreader, as well as for T-track, MFT and L/F clamping applications, making it a useful addition to a woodworking bench or workshop.
Delivering up to 120kg (260lb) of holding force, the clamp provides a useful balance between clamping performance and versatility. An auto-lock mechanism helps secure the clamp in position, while the quick-release lever makes repositioning and removal straightforward. The 50 x 25mm pads provide a practical clamping surface for general workshop tasks.
The clamp features a durable high-carbon steel bar combined with a PA6 body reinforced with 30% glass fibre. It is available in 150mm (6) and 305mm (12) clamping capacities, with a 65mm throat depth. Spreading capacity is 125-285mm for the 150mm model and 125-305mm for the 305mm model.
Axminster develops and selects practical workshop equipment for woodworkers and makers, with a focus on dependable tools that help make workshop tasks more efficient and accurate.
A versatile choice for woodworkers, furniture makers, DIY users and general workshop use where adaptable workholding is required. The 5-in-1 design is particularly useful for anyone wanting one clamp to cover conventional clamping, spreading and bench-based T-track or MFT applications. Available in two clamping capacities: 150mm and 305mm. Choose the size required from the dropdown menu above.
Clamping Capacity 150 mm
Web Attribute Set Quick Clamps
EAN Barcode 5052511147373
