{"product_id":"axminster-7-bar-heavy-duty-roller-stand","title":"Axminster 7 Bar Heavy Duty Roller Stand","description":"\u003cp\u003eThis is a well made heavy duty roller stand able to take a load up to 800kg. The seven 55mm rollers are plated and have fine ribs for maximum strength. These are spaced 305mm apart and are mounted in 100mm x 40mm steel channels. The legs have telescopic inner sections and are adjustable to give a recommended roller height of between 665-1,060mm. Cast steel feet are fitted and these can be individually adjusted by up to 30mm to accommodate an uneven floor. This type of roller stand can be used as a extension to a woodworking table saw or bandsaw and is also able to take the weight of heavy stock used in metal fabrication works. Overall dimensions 2,050mm W x 470mm L. A very useful addition to most workshops.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54117597118811,"sku":"501282","price":219.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/501282_xl.jpg?v=1789767563","url":"https:\/\/www.axminstertools.com\/products\/axminster-7-bar-heavy-duty-roller-stand","provider":"Axminster Tools","version":"1.0","type":"link"}
