This is a well made heavy duty roller stand able to take a load up to 800kg. The seven 55mm rollers are plated and have fine ribs for maximum strength. These are spaced 305mm apart and are mounted in 100mm x 40mm steel channels. The legs have telescopic inner sections and are adjustable to give a recommended roller height of between 665-1,060mm. Cast steel feet are fitted and these can be individually adjusted by up to 30mm to accommodate an uneven floor. This type of roller stand can be used as a extension to a woodworking table saw or bandsaw and is also able to take the weight of heavy stock used in metal fabrication works. Overall dimensions 2,050mm W x 470mm L. A very useful addition to most workshops.
Axminster 7 Bar Heavy Duty Roller Stand
| Web Attribute Set | Material Support |
| EAN Barcode | 5052511059348 |
