{"product_id":"axminster-7-in-1-multi-function-bar-clamps","title":"Axminster 7 in 1 Multi-function Bar Clamps","description":"\u003cp\u003eAxminster 7-in-1 360° Swivel Bar Clamp is a highly versatile clamping solution designed to tackle a wide range of workshop and woodworking tasks with one adaptable tool. Its multifunction design allows it to be used as a conventional bar clamp, spreader, parallel clamp, MFT clamp, T-track clamp or vice, with the swivelling arrangement allowing horizontal and vertical clamping configurations.\u003c\/p\u003e\u003cp\u003eThe 360° swivel design makes it particularly useful when conventional clamps cannot achieve the required angle or position. An auto-lock mechanism helps secure the clamp during use, while a quick-release lever allows fast adjustment and removal. Generously sized 70 x 36mm pads help distribute the clamping load across the workpiece, and the clamp delivers up to 160kg (350lb) of holding force for secure workholding.\u003c\/p\u003e\u003cp\u003eBuilt for regular workshop use, the clamp combines a high-carbon steel bar with a PA6 body reinforced with 30% glass fibre. The range is available with clamping capacities of 150mm (6\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 305mm (12\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 455mm (18\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) and 560mm (24\u003cspecial id=\"32\"\u003e\u003c\/special\u003e). Corresponding spreading capacities are 220-350mm, 220-500mm, 220-650mm and 220-800mm respectively. All sizes have a throat depth of 85mm and use 70 x 36mm pads.\u003c\/p\u003e\u003cp\u003eAxminster develops and selects workshop equipment with practical woodworking and making at its heart, offering tools designed to help achieve accurate, reliable results across a wide range of projects.\u003c\/p\u003e\u003cp\u003eA particularly useful choice for woodworkers, furniture makers and general workshop users looking to reduce the number of different clamps needed for varied workholding jobs. Its ability to switch between clamping, spreading, parallel clamping, MFT, T-track and vice applications makes it well suited to assembly, glue-ups and versatile bench work. Available in four clamping capacities: 150mm, 305mm, 455mm and 560mm. Choose the size required from the dropdown menu above.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"150 mm","offer_id":54438330138971,"sku":"114324","price":15.98,"currency_code":"GBP","in_stock":true},{"title":"305 mm","offer_id":54438330171739,"sku":"114325","price":16.98,"currency_code":"GBP","in_stock":true},{"title":"455 mm","offer_id":54438330204507,"sku":"114326","price":17.98,"currency_code":"GBP","in_stock":true},{"title":"560 mm","offer_id":54438330237275,"sku":"114327","price":18.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114324_xl.jpg?v=1792542267","url":"https:\/\/www.axminstertools.com\/products\/axminster-7-in-1-multi-function-bar-clamps","provider":"Axminster Tools","version":"1.0","type":"link"}
