This drill and plug cutter set enables you to cut plugs up to 50mm in length and then drill the matching holes to accept them. It would be very useful for all sorts of projects where screw heads need to be hidden or where a contrasting plug of timber or other material could be added as a decorative feature. This set includes the sizes 15, 20, 25 and 30mm.
N.B. Only for use in a pillar drill
Web Attribute Set Plug Cutters & Plugs
EAN Barcode 5052511037780
