These Axminster Abrasive Wraps are designed for use with the Axminster Professional AP460DS Drum Sander for an efficient and easy sanding experience.
Cut to 75 x 2,100mm, the sander abrasive wraps are cloth backed and available in 3 grits; 80, 120 and 180g to give you plenty of choice when carrying out your sanding work.
Abrasive Grit 80
Web Attribute Set Drum Sander Machine Loadings
EAN Barcode 5052511144747
