Get the angles right every time when grinding a tool's bevel. The Axminster Sharpening Rest is suitable for most 150mm and 200mm bench grinders. The Sharpening Rest provides a wide stable platform on which to place the tool, it is supplied with a tool clamp that runs smoothly in a groove thus ensuring grinding is square and even. The unit can be moved back and forth on its base and with two pivot points, it is easily set to grind at almost any angle. Fix this jig onto the bench in front of the grinder and forget about the guesswork when trying to accurately reproduce a bevel angle. Takes blades up to 65mm wide.
Supplied with three inserts to suit grinding wheel widths 20mm, 25mm and 32mm.
Vital Statistics:
Base: 65mm wide x 150mm long, four predrilled holes for fixing.
Maximum Height: 150mm with platform level.
Platform: 100mm x 63mm.
Maximum blade width: 65mm.
Web Attribute Set Bench Grinders Accessories
EAN Barcode 5052511002597
