{"product_id":"axminster-adjustable-try-square","title":"Axminster Adjustable Try Square","description":"\u003cp\u003eThis is a real gem of a square; any woodworker will appreciate this tool. It has a wonderful weighty feel with its 3mm thick solid brass blade and 75 x 38mm brass-faced, laminated bamboo stock. The inner edge of the blade is 105mm long, which is a good size and great for general layouts and machine setup.\u003c\/p\u003e\u003cp\u003eLoss of accuracy, due to an accidental knock or drop would render a standard square useless, the only remedy being grinding or filing the blade. This handy square overcomes the problem; two small screws at the base of the stock allow you to adjust and re-calibrate the blade relative to the stock. A fraction of a turn on each is all that is required. This means the square will give you a lifetime of accuracy.\u003c\/p\u003e\u003cp\u003eOverall, size 142 x 80mm, blade width 30mm.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118381453659,"sku":"106477","price":38.28,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/106477_xl.jpg?v=1789777586","url":"https:\/\/www.axminstertools.com\/products\/axminster-adjustable-try-square","provider":"Axminster Tools","version":"1.0","type":"link"}
