Axminster Aluminium Rule - 1m
SKU: 423002
£11.98
£9.98 Excl. VAT
  • One bevelled and one calibrated edge
  • Anti-slip insert
  • Drilled for hanging
  • 1,000mm length
  • Compataible with the Axminster mount Cutter
Drilled at one end to enable it to be hung up out of harm's way when not in use. Excellent combined rules/straight edges have one bevelled and calibrated edge and an anti-slip insert on the underside. Compatable with the Axminster mount Cutter.
Web Attribute Set Rules Rule Length: 1,000 mm
EAN Barcode 5052511021741
