The Axminster Professional Angle Rule revolutionises accuracy in marking with its patented marking holes and slots. Using a 0.5mm mechanical pencil, it is designed to eliminate measurement errors, with its patented marking holes for precise, error-free markings.
The 180mm rule features slots that run from one face to another, ensuring accurate transfer of markings. It is perfect for edge measurements, with micro-fine holes at every scale line for exact placement. The 90-degree shape fits snugly against workpieces, and it includes two vertical end scales for drawing parallel lines. Supplied with a mechanical pencil and refills for added convenience.
Web Attribute Set Rules
EAN Barcode 5052511132553
