Upgrade your AP254SB table saw with a precision-machined aluminium table insert plate designed to deliver cleaner cuts, improved safety, and greater control. Engineered as a direct replacement for the standard unit, this insert is intended for use with the blade set at 0°, creating a significantly tighter gap around the blade. This close fitting design helps prevent small offcuts from dropping beneath the table while providing crucial support to smaller workpieces, reducing vibration and making fine, accurate cuts easier to achieve.
Supplied with a convenient starter slot, the insert allows for simple and precise kerf creation. Just install the plate with the blade fully retracted, power on the saw, and gradually raise the blade through the aluminium to form a perfectly matched opening. Thanks to its non-ferrous construction, the aluminium will not damage your blade during this process, ensuring both safety and longevity.
Installation is quick and secure, with a five-point screw fixing system that makes removal and replacement straightforward. Integrated levelling grub screws allow you to fine tune the plate so it sits perfectly flush with the table surface, ensuring smooth material handling and optimal cutting performance. Built for durability and consistent accuracy over time, this insert plate is an essential upgrade for anyone looking to get the most out of their AP254SB table saw, delivering enhanced precision, improved safety and reliable results.
