Axminster Barrel Plug Cutters
SKU: 950190
£16.68
£13.90 Excl. VAT
  • For cutting plugs and short dowels up to 50mm in length
  • Timber can be matched to cover screw heads etc
  • Clean cutting and easy plug removal
  • For use in drill presses only
These barrel cutters will cut plugs and short dowels up to 50mm in length, when matched with a corresponding drill they can be used to cover screw holes or make a small repair in damaged timber, they also make a good decorative plug. Designed for use in a drill press they give a very clean cut.
Plug Diameter 30 mm
Web Attribute Set Plug Cutters & Plugs
EAN Barcode 5052511045518
