Axminster Workshop
Axminster Blade Reducing Bushes
SKU: 810365
£2.28
£1.90 Excl. VAT
  • 30mm outside diameter
  • Standard 2mm thick
  • Range of bore sizes available
Saw blade reducing bushes all with a standard 30mm outside diameter. They are 2mm thick (please check your blade's plate thickness) and available in a range of bore sizes. N.B. Please check that your saws blade clamping discs are larger than 30mm in diameter, otherwise they will not clamp the blade.
Made in Britain Yes
Diameter 30
Bore Size 15.88 mm (5/8)
Intended Use To reduce the bore of a circlar saw blade to fit smaller arbors.
Web Attribute Set Circular Saw Blade Accessories
EAN Barcode 5052511042012
