This is the ideal companion to the bench top edgebander and edgebanding trimmer. Anyone who has used edgebanding will know how difficult it is to get a perfectly trimmed end. With this tool a single press down on the handle operates the blades in a shearing action. The blades are reversible so when the cutting blade becomes dull simply change places with the anvil blade. The end trimmer cuts banding or veneer up to 0.5mm thick with a maximum cutting width of 54mm.
Plug Fitted UK 3 pin plug
Web Attribute Set Edgebanders Portable
EAN Barcode 5052511026340
