A milling vice is wonderful for clamping work which is true, square, parallel etc. but when it comes to odd shaped items like castings then the only answer is to clamp it. This very useful piece of equipment consists of 24 studs (4 each 75, 100, 125, 150, 175 and 200mm), six T-nuts, four coupling nuts, six flange nuts, six step clamps and six step blocks. All parts are heat treated, black oxide finished. The studs are M10 to suit 12mm table T-slots, especially the Axminster Sieg X2, Super X2, X3 & Super X3 machines.
Axminster Engineer Series 12mm T-Slot Clamp Kit for Mills
| Web Attribute Set | Milling Tooling & Accessories |
| EAN Barcode | 5052511047819 |
