A three position drilling vice with ground faces and slideways for accurate and precise operation. The jaws have triangular grooves for gripping circular items, both horizontally and vertically, and there are recesses in the tops of the jaws for gripping smaller items. In order to save space on the drill table the handle is held captive in the frame and the lead screw retracts into it as the jaws are opened. The vice has three machined mounting faces, each equipped with clamping slots or holes, which allow holes to be drilled at right angles to each other without the need to re-position the work.
Axminster Engineer Series 3-Way Unigrip Vertical/Horizontal Drill Vice
| Jaw Width | 125 mm |
| Nett Weight | 7kg |
| Base Size | 180 x 242mm Web Attribute Set: Drilling Machine Vices Jaw Depth: 30mm Jaw Opening: 120 mm |
| EAN Barcode | 5052511007776 |
