{"product_id":"axminster-engineer-series-8-piece-medium-adjustable-reamer-set","title":"Axminster Engineer Series 8 Piece Medium Adjustable Reamer Set","description":"\u003cp\u003eA set of 8 adjustable reamers with a size range of 15\/32\u003cspecial id=\"1\"\u003e\u003c\/special\u003e-1-1\/32\u003cspecial id=\"1\"\u003e\u003c\/special\u003e (11.90-26.20mm). Each reamer has an adjustment range of 1\/16\" (1.58mm) except the two largest sizes which are of 3\/32\u003cspecial id=\"1\"\u003e\u003c\/special\u003e (2.37mm) range. If you need to produce a perfectly sized and concentric hole in a bush or pivot ect then a reamer is the tool to use. Having a square drive end of 5.5-12mm makes them easy to use with a suitably sized hand tap wrench. Every engineer should have a set.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54116929995099,"sku":"950132","price":43.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/950132_xl.jpg?v=1789763598","url":"https:\/\/www.axminstertools.com\/products\/axminster-engineer-series-8-piece-medium-adjustable-reamer-set","provider":"Axminster Tools","version":"1.0","type":"link"}
